Modifying viewports
There are various ways to modify viewports; their appearance can be completely different from the original design layers for presentation purposes. For a styled viewport, you might need to edit the style or change the viewport to be unstyled before making modifications; see Creating and editing viewport styles.
Modification |
Description |
Access various viewport editing modes; set preferences for editing viewports |
Change the settings for the viewport in the Object Info palette |
Edit the viewport style |
Modify the viewport with various 2D and 3D tools and commands; copy and move viewports |
Add annotations and dimensions to the viewport |
Add depth cueing to sheet layer viewports and section viewports |
Crop the viewport |
Edit one or more design layers in a live section or elevation |
Edit a design layer displayed in the viewport |
Change the visibility of objects, classes, and/or layers from the design layer or when editing a linked camera on a sheet layer |
Edit or delete a linked Renderworks or video camera |
Change the properties of the viewport's layers and classes |
Changing the layer properties of sheet layer or design layer viewports Changing the class properties of sheet layer or design layer viewports |
Change the attributes of the objects in the viewport based on their data (Design Suite product required) |
Change the visibility and appearance of structural grid lines in viewports |
Structural grid visibility in viewports and Grid line instance visibility in viewports |
